See more
See less
Help SG3524 based charger
  • Help SG3524 based charger
    Hello everyone,
    I do not understand what goes where and want someone to help me
    How do I change picture added
      you should be able to edt your own posts.
        I can edit text
        only with schematic i can't
        is pasabele to delete schematic to make new one
          That might help!
          Martin B
            Thank you Martin B
            I need Solid state see 1 schematic
              Originally posted by Martin B View Post
              That might help!
              [ATTACH=CONFIG]3028[/ATTACH]
              Martin B
              Hey Tom C, remember when we first met and Rick was describing this setup to you? (I was too busy hangin' out with JB)
              Did you ever try this one out?
                John K,
                I remember being in the shop and him talking about the inverted circuits, but honestly at that point I was way in over my head I also remember him being very "dont look at it too hard" sort of attitude so I tried not to....... I could never get him to tell me how far apart the antennas were.... the circuit reminds me of the ground radio and stubblefield.
                http://www.icehouse.net/john1/groundradio.html
                  Tom C, thanks for the link. I don't remember ever seeing that page.
                  I thought the antenna was like the one shown in the FEG book. Anyway, did Rick tell you what the size of the first "Very large cap" was? The only way I can think that this circuit would work properly is if that cap was a low uF HV one, something like 10uF 450v. The other bank of caps would be high uF, low voltage - something like 60,000uF 80v.
                    that makes sense to me, the large cap would work better low Uf hi voltage, that way you get the whole spike into the cap. I am not totally sure where the gains from the antenna get into the recieving battery, or what exactly is switching the opto, I have never seen an opto driven from a radiant antenna intput. there are no pinouts for the chip, loooks like the small cap up top on the left side drives the 3524.
                      The 3524 would have to be externally powered, a 9v battery would probably do. It in turn switches the optos to fill and spill the cap bank.
                      I might string up an antenna on the weekend and see what I can get out of it. On the other hand, that page of JB's you put the link up for has some very interesting ideas. Hmmm, water and natural gas pipes are copper
                        that old website has lots of cool stuff including his Rife research.
                          can someone answer and explain what prompted with
                          red where it's going and how much voltage connection 12v
                          see photo first post
                            Why some posts seem to go unanswered
                              Hi Ed,
                              Sorry but I don't understand your question. Post in Dutch if you like. We can use Google to translate it. (Or my mum & dad, they are both Dutch )
